Questions about configuring intellisnap for NetApp and Oracle
  • February 14, 2022
  • 170 views
Hi experts,
I got a question about Oracle DB backup and NetApp Snapshot from a customer.
Customer plans to perform the Oracle Backup using Intellisnap for NetApp iSCSI LUN.
I checked the requirements for NetApp Storage in the documentation web.
https://documentation.commvault.com/11.25/expert/33744_system_requirements_for_netapp_storage_array.html
Is there anything they need to do before creating a Volume of Oracle data on NetApp Storage?
I'd like to know if there are any special pre-works that need to be done on NetApp storage.
Best Regards
Kim KK
Best answer by R Anwar
Hi @KyungKee Kim
I would recommend to check NetApp IMT for compatibility on Oracle and ONTAP.
R Anwar
  • February 14, 2022
Hi @KyungKee Kim
