Questions about Continous Replica
  • March 30, 2023
  • 62 views
Hi everyone, I have some questions about continous replica (vaio).
The first question is about RPO: what is the minimum RPO that can be achieved with the vaio replica? Can it also be of seconds? And the retention of how many hours or days is it?
The second is about the issue described here: https://documentation.commvault.com/11.24/disaster_recovery/106456_known_issues_for_continuous_replication_in_command_center.html
“If a virtual machine is replicated to a destination site and you perform a restore operation for the VM at the destination site, the replicated VM and the restored VM have the same UUID”
What exatly mean? Do I have to answer “I copied” everytime I power on a replica vm?
Thank you
Hi @Luca82 ,
I will ask Development to check and get back to you.
Sebastien
