Ransomware Honeypot detection
  • February 10, 2022
  • 923 views
i only have about 50 physical servers - all have CV agents - whereas i have about 500 virtual machines that get backed up via a vcenter vm backup.  Question about the honeypot detection … do the 500 virtual machines get detected for ransomware in any sort of fashion or what is the guidance there?  Thanks!
Best answer by Mike Struening
@JamesLincoln , directly through the VSA on the roadmap.
However, you can install the File System agent and it will work with agent present.
From the docs:
https://documentation.commvault.com/11.24/expert/7879_monitoring_file_anomalies_on_client_computers_01.html
Note: Anomaly detection can be enabled on virtualized environments by installing the base Windows file system restore-only client in the virtual machine guest host. For more information, see Installation of Restore Only Agents.
From the docs:
