I have four MA in prod, (partitioned ddb) with 3 installed in the E; drive. which is the standard here. I have a couple dozen other configured the same.
one of the four is installed in C; drive and must be re-installed to E:. (for scripting purposes)
That would be the install directory to a different drive. These MA are an evergreen project (24 servers), and scripts require the executables at a folder in e: .. Do not need to move DDB, it’s in the right drive and should be unaffected.
So uninstalling and re-installing is easy enough, however does the this work with the CS?
In Media Management I am not an expert on the CommServe. To avoid possible issues or data loss I would recommend creating a support case for our Server Team to properly advise you on the re-install process for the CommServe.
