Rebuild Commserv instance
  • May 17, 2023
  • 7 replies
  • 368 views
Forum|alt.badge.img+2
Hi All,
In one of our customer site, “cvd.exe” file got removed (We suspect anti-virus software for this). We couldn’t repair the instance as it gives errors due to “cvd.exe” file being missing. Since the CSDB is ok and fine we did a failover to the DR commserv and operations are continued.
Now we want to do an instance (instance 001) only restore for the commserv. We couldn’t find any documents regarding this kind of rebuild. Can anyone help us with a proper documentation link or steps.
Best answer by Javier
I might be a bit late to the party.
Please check the following documentation;
https://documentation.commvault.com/2023/essential/105908_reinstalling_production_commserve_host.html
In a nutshell, if you ever need to rebuild the production CS, the official procedure is to failover to your standby node (as you did), which will become the active node in the environment, and then reinstall the former production CS as a standby CS. You can then failback again.
Hi @Suranjan ,
You should be able to copy cvd.exe from another Client on that same version.
Have you tried that?
Sebastien
  • May 17, 2023
Hi @Sebastien Merluzzi,
Thank you for your reply.
Yes, we tried that. Even after that cvd services did not worked. Then we uninstall the commserv instance.
Thanks & Regards,
Suranjan
oh ok, I think it would better to log a case with Support so we can check.
Do you actually Backup the instance?
Installing a new Commserve with existing DB is not an option?
https://documentation.commvault.com/2022e/expert/1733_installing_commserve_server_in_windows_environment.html
  • May 17, 2023
Thank you for your follow up.
We are following up this with a support case. Commvault currently trying to reinstall with a full media kit.
We have a failover instance and we already failover to the DR instance.
Thanks & Regards,
Suranjan
clecky
Forum|alt.badge.img+13
  • May 17, 2023
You should probably investigate ransomware.
Antivirus is the optimistic thought here, but ransomware has a vested interest in making sure your commserve is down.
Also I have never heard of Antivirus simply deleting files without warning.
  • May 17, 2023
Hi @clecky ,
Thank you for your insight.
Commcell env is pretty isolated in our setup. Antivirus SW only installed recently (in the first week of May). That’s why we are suspecting the antivirus to be the case.
I’ll notify the team to investigate this further with the possibility of Ransomware attack.
Thanks & Regards,
Suranjan
  • July 12, 2023
