Removing old storage primary copy and related ddb databses
  • April 25, 2023
  • 394 views
Forum|alt.badge.img+16
hello All,
we were using disk library and 2 physical server as our MA , recently we procured hyperscale x 3 nodes and created a cluster , and storage policy and we created aux copy in all the storage policy and copied all the data , then we switch it to as the primary copy ,
we decommissioned our old media agent , now we are getting old ddb related alerts and job failure
i have disassociated old MA from system schedule policy
please help me how to get clean of old disb library ,MA , dedup engine and databases , can someone help me necessary steps to take
Alert: Commserv Anomaly Alert Type: Operation - Admin Alert
The system detected an unusual drop in the pruning performance for the following databases in commcell
Best answer by Orazan
Is the DDB to the library that you want to remove still holding jobs?  You will not be able to delete a DDB that has active jobs in it.  You will have to manually delete those jobs or have them age before the DDB can be removed.
Forum|alt.badge.img+18
  • April 25, 2023
  • April 25, 2023
@Orazan  can you help me with the stpes for perform the same
like check for the jobs , delete ,aging the job
we copied all the jobs from sp to new hyperscal x sp , i belive we dont require the old ddb
