Replication pending
  • October 10, 2023
  • 170 views
Alvian
Apprentice
Forum|alt.badge.img+5
I have a question
My replication database always pending and i check log for the result :
Error-: Database 'msdb' cannot be opened due to inaccessible files or insufficient memory or disk space.  See the SQL Server errorlog for details.An exception occurred while executing a Transact-SQL statement or batch..
17156 3a68  10/10 09:07:23 76571 CSQLRestoreBase::getAFilesToRestoreForLiveSync(8704): -Error-: Failed to get last restore point for server [COMMVAULT-CS-3\COMMVAULT] with error [0xEDA00077:{CSQLRestoreBase::GetLastRestorePointForLiveSync(8688)/CV.0x77-Failed to get last restored state of database [WFEngine] for live sync.}].
17156 3a68  10/10 09:07:23 76571 CSQLRestoreBase::GetAfilesForAllDatabases(10292): -Info--: Failed to get AFile information or no AFile information found on the CS for database [WFEngine].
17156 3a68  10/10 09:07:23 76571 CsqlDMO::getDBLastRestoreInfo(6167): -Error-: Database 'msdb' cannot be opened due to inaccessible files or insufficient memory or disk space.  See the SQL Server errorlog for details.An exception occurred while executing a Transact-SQL statement or batch..
17156 3a68  10/10 09:07:23 76571 CSQLRestoreBase::getAFilesToRestoreForLiveSync(8704): -Error-: Failed to get last restore point for server [COMMVAULT-CS-3\COMMVAULT] with error [0xEDA00077:{CSQLRestoreBase::GetLastRestorePointForLiveSync(8688)/CV.0x77-Failed to get last restored state of database [UsageHistoryDB] for live sync.}].
17156 3a68  10/10 09:07:23 76571 CSQLRestoreBase::GetAfilesForAllDatabases(10292): -Info--: Failed to get AFile information or no AFile information found on the CS for database [UsageHistoryDB].
17156 3a68  10/10 09:07:23 76571 CSQLRestoreBase::getAFilesToRestoreForLiveSync(8704): -Error-: Failed to get last restore point for server [COMMVAULT-CS-3\COMMVAULT] with error [0xEDA00077:{CSQLRestoreBase::GetLastRestorePointForLiveSync(8688)/CV.0x77-Failed to get last restored state of database [DM2] for live sync.}].
17156 3a68  10/10 09:07:23 76571 CSQLRestoreBase::GetAfilesForAllDatabases(10292): -Info--: Failed to get AFile information or no AFile information found on the CS for database [DM2].
17156 3a68  10/10 09:07:23 76571 CSQLRestoreBase::getAFilesToRestoreForLiveSync(8704): -Error-: Failed to get last restore point for server [COMMVAULT-CS-3\COMMVAULT] with error [0xEDA00077:{CSQLRestoreBase::GetLastRestorePointForLiveSync(8688)/CV.0x77-Failed to get last restored state of database [CVCloud] for live sync.}].
17156 3a68  10/10 09:07:23 76571 CSQLRestoreBase::GetAfilesForAllDatabases(10292): -Info--: Failed to get AFile information or no AFile information found on the CS for database [CVCloud].
17156 3a68  10/10 09:07:23 76571 CSQLRestoreBase::getAFilesToRestoreForLiveSync(8704): -Error-: Failed to get last restore point for server [COMMVAULT-CS-3\COMMVAULT] with error [0xEDA00077:{CSQLRestoreBase::GetLastRestorePointForLiveSync(8688)/CV.0x77-Failed to get last restored state of database [CommServ] for live sync.}].
17156 3a68  10/10 09:07:23 76571 CSQLRestoreBase::GetAfilesForAllDatabases(10292): -Info--: Failed to get AFile information or no AFile information found on the CS for database [CommServ].
17156 3a68  10/10 09:07:23 76571 CSQLRestoreBase::getAFilesToRestoreForLiveSync(8704): -Error-: Failed to get last restore point for server [COMMVAULT-CS-3\COMMVAULT] with error [0xEDA00077:{CSQLRestoreBase::GetLastRestorePointForLiveSync(8688)/CV.0x77-Failed to get last restored state of database [AppStudioDB] for live sync.}].
17156 3a68  10/10 09:07:23 76571 CSQLRestoreBase::GetAfilesForAllDatabases(10292): -Info--: Failed to get AFile information or no AFile information found on the CS for database [AppStudioDB].
I checked the memory and disk, there was still plenty
Any Ideas?
Best answer by Vsicherman
Try rebooting the destination node, if issue persists you’ll probably want to open up a support ticket.
  • October 10, 2023
Alvian
Apprentice
  • October 11, 2023
@Vsicherman Thanks for your suggest it’s works
