Report for Application Size per Client
  • September 11, 2023
  • 239 views
Dear Community,
I need a report at the beginning of each month for the sum of the "Application Size", independent of "Application Type" and "SubClient", of Clients within a "Client Group" from the previous month.
I have tried to find out the information using the report "Backup job summary", but I only get the sizes per job and not per client.
Which report can I use to map my requirements?
Can someone help me?
Thanks a lot!
Best answer by Navneet Singh
@ohajek
Please try with the Chargeback details report and let us know if it helps.
https://store.commvault.com/webconsole/softwarestore/store.do#!/135/666/13172
  • September 12, 2023
@ohajek
Hello Navneet,
thanks for the quick reply, the report should be sufficient for my purposes.
