Report for total data written
  • Jun 9, 2024 5:41 PM UTC
  • 226 views
Can we generate the report for a storage policy to see how much data written daily?
For example, I have a storage policy that is scheduled for incremental from Monday to Thursday, and a full on Friday. Can I generate a report to see how much data is written on the full backups on Friday?
Thank you.
Best answer by Mauro
The Backup Job Summary Report will have this information for you in the Java Console
You’ll change the Storage Policy Info on Storage Policies Tab. You’ll then select ‘Full’ under the Options Tab.
The report will look like the below. You’ll want to focus on the Size of Application info (front end size) and the Media Size (data written post dedupe and compression)
You could also download the below report from the store and get the same info using the parameters you require.
Forum|alt.badge.img+16
  • Jun 10, 2024 8:57 AM UTC
You can refer to this documentation link for Backup Job Summary report details
https://documentation.commvault.com/2023e/expert/default_data_views_for_backup_job_summary_report.html
  • Jun 10, 2024 2:06 PM UTC
@Mauro thank you so much. The report within the Java console works like a champ.
