Report for VM machines failed backups
  • March 14, 2023
  • 170 views
We use intelliSnap to backup our NetApp datastores. Sometimes, the backups are completed, but some of the VMs in the datastores failed. I wonder if we can generate a report for the individual VMs that failed?
Best answer by Sebastien Merluzzi
or under Agent Type, can you select Virtual Server as below:
You can create Alerts when a job is failing/completing with errors.
You will not be able to specify the Datastore though.
However you can add the VMs from that specific Datastore in a Client Group and then specify that Group under the Alert options:
Hi @TD89 ,
The Job Summary Report will be for the whole job(s), but you can generate a report as csv and then filter for failed VMs.
Sebastien
  • March 14, 2023
Hi @Sebastien Merluzzi
Thank you for a super quick answer :), Also, can I have email alerts for the failed backup VMs? We do have the email alerts for the whole datastores when their backups failed.
  • March 15, 2023
Thank you so much @Sebastien Merluzzi  👍
