Reports - unit of measure
  • September 14, 2022
  • 211 views
Hello
Can anyone tell me what the unit of measure is on the report “Backup Job Summary Report” ?  The columns I need clarification on are all the size related columns.
  • Size of Application
  • Data Transferred
  • Data Written
  • Data Size Change
I assume they are in bits or maybe bytes but I cannot find the answer for certain.
Also, does anyone know which API endpoint I could use in place of this report?
Best answer by Jupalli
Hello Dave, All sizes in the report are auto formatted in the report viewer, the sizes are shown in the KB, MB, GB or TB ..etc.  the size returned by the backend is in bytes.
the report table menu has the option show the REST API.
Venkat
Forum|alt.badge.img+2
Venkat
  • September 16, 2022
Hi
Thanks for the info.
Looking at the size of the databases we back up and the “Data Written” returned from CV it really looks like the size is bits to me.
  • September 19, 2022
All Sizes returned by the query in the web “Backup Job Summary” report are in Bytes for all the datasets.
