Resetting tape library while aux/backup job running
  • November 15, 2022
  • 185 views
Forum|alt.badge.img+18
Hi there,
I have a quick question. I need to reset tape library to apply new changes, but some aux jobs are still running and I need them to be continued after resetting the library. So, should I put the aux jobs to suspanded state or rather then  to put the tape library offline for the maintenance and then reset it? The key thing is not to lost progress of running aux jobs.
Best answer by Orazan
Good morning.  You can suspend the job, reset the library and then resume the job.  It should pick up right where it left off.
  • November 15, 2022
  • Challenger
  • November 16, 2022
Hi @Orazan, thank you so much for the clarification! Now, I am completely sure about resetting the library.
