Restore cluster MongoDB out of place error
Hello, Community.
Has anyone encountered this error when restoring a cluster to the out of place?
Who can explain the occurrence of this error?
Error Code: [23:93]
Description: Either the map file was not found, could not be used, or the map file does not contain any vailid entry. Users choice allows only map-based restore. Nothing to restore.
CV_GK
  • July 29, 2025
Hi ​@cmvt_user
The error message you are encountering indicates that the map file required for the restore operation is either missing, invalid, or does not contain any valid entries.
What is the CV and DB version being used?
  • July 29, 2025
Hi ​@cmvt_user
if I understood you correctly
CV version 11.32.42
DB version (MongoDB)  4.4
