restore office 365 mailbox from secondary copy
  • March 13, 2023
  • 127 views
Forum|alt.badge.img+5
How can i restore office 365 mailbox from secondary copy.
Regards.
Best answer by Chris Hollis
Hi @Elmahdi Achraf
Unfortunately the agent doesn't allow us to specify a copy precedence for restore purposes, it's default is the primary.
If data verification succeeds for the jobs on secondary, you won't have any issues recovering from it in the event of a disaster (assuming it's location is also not impacted).
You can either verify integrity of just the jobs on the copy itself by following these steps:
https://documentation.commvault.com/2022e/expert/8913_data_verification.html
Or you can verify all jobs written to the DDB engine as per:
https://documentation.commvault.com/2022e/expert/12569_performing_data_verification_operation_on_deduplicated_data.html
So long as verification doesn't fail or highlight any individual job failures, the data is readable.
Hopefully this helps,
Chris
Chris Hollis
Hi @Elmahdi Achraf
Out of curiosity, what has happened to the primary copy?
Here is a link to what has to occur in order to recover from a secondary copy for the MB Agent: https://documentation.commvault.com/2022e/expert/146271_recovering_data_from_secondary_copy_for_exchange_mailbox.html
Chris
The primary copy is working fine, it's just a test of secondary copy.
We need to restore somme files to be sure that the secondary copy is working fine.
Chris Hollis
  • March 14, 2023
Hi @Elmahdi Achraf
Chris
Nikos.Kyrm
Forum|alt.badge.img+16
  • Community All Star
  • September 3, 2024
Hello @Chris Hollis
So, for o365 (Exchange Online, OneDrive & SharePoint Online) there is still no way to directly restore from 2nd copy? Because of INDEX, right?
The only way I assume is to promote 2nd copy to Primary and then restore from 2nd copy?
Best regards,
Nikos
