Restore oracle out of place fail
  • May 2, 2022
  • 1009 views
When i perform a restore of instance oracle on another vm , i have this error :
Error Code: [18:106]
Description: RMAN Script execution failed with error [ORA-19698: D:\DATA\WATTSDAT\REDOLOG\REDO01.LOG is from different database: id=3217969858, db_name=WATTSDAT]. Please check the Logs for more details.
Source: 33-wt172-de-all, Process: ClOraAgent
Can help me
Thks
Dario
Best answer by Gowri Shankar
Hi @DarioV ,
The destination server needs a blank database instance started in nomount mode before the restore is initiated.
Please refer to the before you begin section from the documentation
https://documentation.commvault.com/11.24/expert/20457_restoring_oracle_online_backup_to_new_host_cross_machine_restore_with_same_directory_structure.html
Gowri Shankar
Forum|alt.badge.img+16
Good day @DarioV
The destination directory may not be empty or may contact files from the previous DB.
Please ensure to clear the contents from the destination machine before rerunning the restore.
Gowri Shankar
  • May 3, 2022
Hi Gowri,
Excuse a stupid question, but on the target vm do I have to create an empty instance before the restore or does commavult do everything by itself?
Thks
Dario
Hi @DarioV ,
Gowri Shankar
