Restore permission restriction
  • Feb 11, 2025 10:52 PM UTC
  • 75 views
I would like to know if there are ways to restrict restoration user permission from AUX copies and only allow the restores from the Primary copy.
Forum|alt.badge.img+9
Hi ​@Rajkumarrdn
There is currently no out of the box way to do this but if you are ok doing some coding then one possibility is to create a business logic workflow to force the copy precendece to be primary copy when a restore is started. There are some pre-built Business logic workflows for restore in the commvault store which you can use as the starter. here is an example.
https://cloud.commvault.com/webconsole/softwarestore/store.do#!/136/670/12183
here is the documentation for business logic workflows
https://documentation.commvault.com/2024/essential/creating_business_logic_workflow.html
