Answer
Restoring an oracle RAC DB to another RAC failing
  • May 10, 2022
  • 2849 views
Forum|alt.badge.img+8
Hello Dears,
Seeking your support to enlighten  me with a sloution for a failing cross restore oracle rac
according to the RMAN LOG the db restore completed but there was an error restoring a specific logfile.
RMAN-00571: ===========================================================
RMAN-00569: =============== ERROR MESSAGE STACK FOLLOWS ===============
RMAN-03002: failure of recover command at 05/10/2022 19:46:46
RMAN-11003: failure during parse/execution of SQL statement: alter database recover logfile '+FRA/bopdb/archivelog/2_5216_1074853752.dbf'
ORA-10877: error signaled in parallel recovery slave
RMAN>
Recovery Manager complete.
so we are unable to bring the db online.
ERROR:
Error Code: [18:190]
Description: RMAN Script execution failed for instance [BOPDB1] with error [ORA-10877: error signaled in parallel recovery slave ]. Please check the Logs for more details.
Source: node1, Process: ClOraAgent
appreciate your fast response.
restore steps
1 - restore type : out of place
2- restore options : restore control file , restore data, no catalog, recover
3- Advanced : general : use rman restore
4- redirect : redirect all tablespaces and tempfile and online logs to > <path>
5- ctrl&SP files >restore control file > from auto backup
to point of time > completion time provided in the job details
Best answer by Gowri Shankar
Hi @Muhammad Abdullah
The job went into pending after all the data including the archive logs are restored from commvault.
The recovery fails due to following error
channel ch1: restored backup piece 1channel ch1: restore complete, elapsed time: 00:02:45archived log file name=+FRA/bopdb/archivelog/1_12437_1074853752.dbf thread=1 sequence=12437archived log file name=+FRA/bopdb/archivelog/2_5216_1074853752.dbf thread=2 sequence=5216released channel: ch1released channel: ch2RMAN-00571: ===========================================================RMAN-00569: =============== ERROR MESSAGE STACK FOLLOWS ===============RMAN-00571: ===========================================================RMAN-03002: failure of recover command at 05/10/2022 19:00:40RMAN-11003: failure during parse/execution of SQL statement: alter database recover logfile '+FRA/bopdb/archivelog/2_5216_1074853752.dbf'ORA-10877: error signaled in parallel recovery slaveRMAN>
Could you connect to the destination instance and review the oracle alert log for additional information related to this error around timestamp 05/10/2022 19:00:40
Gowri Shankar
Forum|alt.badge.img+13
Gowri Shankar
Hello @Gowri Shankar
please find the below screenshot from the destination db
Could you attach the alert log please
Gowri Shankar
@Muhammad Abdullah , following up on this one.  Were you able to get this resolved or open a support case?
