Retire offline laptops
  • April 29, 2024
  • 10 replies
  • 112 views
I'd like to know how to check that my ‘Retire laptops when they are offline for...’ and ‘Delete retired laptops after’ settings are working properly ?
the number of laptops is not decreasing…
thanks a lot
Please check that the endpoint or laptop is able to establish communication with the CommServe during the deletion process. If there's a lack of communication, the device will not be deleted from the CommVault database.
Attempt to reconnect the endpoint or laptop to the network and then proceed with the deletion process. If necessary, perform a manual uninstallation directly from the endpoint or laptop.
https://documentation.commvault.com/v11/essential/retiring_laptop.html
Thank you.
  • April 29, 2024
hi,
you didn’t understand :
see screenshot ( yellow section )
when i choose 10 months in the option ( Retire laptops when they are offline for ), my total laptop is not decreasing…
  • April 29, 2024
Retire laptop when they are offline for :
box specify the time after which the offline laptop is uninstalled automatically.
Additionally, after the specified time elapses, the offline laptops without any associated backup data are deleted. The offline laptops with associated backup data are left deconfigured so their data is available for potential restoration.
So when this time elapse you can see it in total laptop but it will be in DE configured state.
Delete retire laptops:
 After the time elapses, the Commvault software purges the deconfigured laptop's data from the system. Subsequently, you cannot restore the data from such laptops.
After this it won't show in total laptops.
When you change any of these values you can verify these columns in laptop listing page.
  • April 29, 2024
i don’t have in colums choice : Days until Deleted neither Days until retired !!!
screenshot attached
  • April 29, 2024
Thats not the right place. Verify in protect->laptop->laptops
  • April 29, 2024
….i do not have, sorry…. screenshot attached
  • April 29, 2024
  • April 29, 2024
What is the CommServe SP level ? All these options are there in SP32
  • May 3, 2024
Version: 11.28.83 Commvault
platform release: 2022E
  • May 3, 2024
Ok. Once you upgrade to SP32 you will get these. Not in Sp28.
