RHE Linux Requirements for IBM Spectrum Scale (GPFS)
  • May 4, 2026
  • 120 views
For Red Hat Linux requirements for IBM Spectrum Scale (GPFS); does it support Red Hat Enterprise Linux 9.x?
Documentation online says Red Hat Enterprise Linux 9.0 but it could be a typo.
System Requirements for for IBM Spectrum Scale (GPFS)
Best answer by Jace Ross
@Jace Ross Thank you a quick reply. I am assuming that 9.6 is supported as well?
Correct, all versions of 9 are supported. 10 has not yet been tested.
Cheers,
  • May 5, 2026
Hi Brandon,
I’ve checked internally and RHEL 9 is tested and supported for GPFS.
Cheers,
  • May 5, 2026
  • May 5, 2026
Cheers,
  • May 6, 2026
@Jace Ross Thank You. Hopefully Documentation Online can be corrected or made clearer.
