RMAN-05548 The set of duplicated tablespaces is not self-contained
  • April 17, 2022
  • 329 views
I have a problem when I table restore.  (ORACLE 19C)
Below error occurs.
RMAN-05548 The set of duplicated tablespaces is not self-contained.
What should i do?
Best answer by Orazan
Good morning.  When attempting to restore, can you try right clicking on the table?  Do you see an option to “select dependent tables”?  If so can you select it and retry the restore please?
Forum|alt.badge.img+18
  • April 17, 2022
  • April 17, 2022
Good morning.
Yes. I can.  I will try.
Thank you. ^^
