RMAN failed to load SBT library
  • February 25, 2026
  • 230 views
Hi community.
We recently configured the Oracle agent on a Linux machine, the instance is discovered and configured. But when checking the readiness, it gets the error below:
Connect string: /
SBT library path: /backup/catalyst/commvault/Base/libobk.so
RMAN failed to load SBT library [RMAN-03009: failure of allocate command on c1 channel at 02/24/2026 16:49:34 ORA-19554: error allocating device, device type: SBT_TAPE, device name: ORA-27211: Failed to load Media Management Library ]. Please run Check Readiness on the client to diagnose and resolve the issues.
Checking the logs, I see the lines below:
39612 9abc 02/10 16:15:29 ### SetOracleBaseEnv(6236) - Failed to execute script [/backup/catalyst/commvault/Base/Temp/orabase_39612.sh] returnCode [126] output [] errorStr [ERROR: ld.so: object '/backup/catalyst/commvault/Base/libCvDllFilter.so' from LD_PRELOAD cannot be preloaded: ignored.
bash: /backup/catalyst/commvault/Base/Temp//ulimitquery_67447.sh: Permission denied
Does anyone have faced the above errors?
Thank you.
CV_GK
  • March 2, 2026
Hi ​@Hansel.Flores
What is the CV, DB and OS version?
Did you set unix group during Oracle iDA install?
  • March 13, 2026
Hi ​@CV_GK
The CV version is 11.40.19
DB: Oracle 19.22
OS: RedHat 7.9
Below is a what I see in the RMAN log:
Copyright (c) 1982, 2019, Oracle and/or its affiliates.  All rights reserved.
RMAN>
connected to target database: FMSP (DBID=1182894984)
using target database control file instead of recovery catalog
RMAN> 2> 3> 4> 5> 6> 7> 8> 9> 10> 11> 12> 13> 14> 15> 16> 17> 18> 19> 20> 21> 22> 23> 24> 25> 26> 27> 28> 29> 30> 31> 32> 33> 34> 35> 36> 37> 38> 39> 40> 41> 42> 43> 44> 45> 46> 47>
RMAN-00571: ===========================================================
RMAN-00569: =============== ERROR MESSAGE STACK FOLLOWS ===============
RMAN-03009: failure of allocate command on ch1 channel at 03/12/2026 16:44:28
Additional information: 4176
RMAN>
Not sure what is that lib libCvDllFilter.so about, any clue?
CV_GK
  • June 5, 2026
Hi ​@Hansel.Flores
Please share output of below command from oracle client's RMAN prompt
run
allocate channel c0 type 'sbt_tape';
release channel c0;
