SAP BR*TOOLs execution failed
  • October 27, 2021
  • 6863 views
Forum|alt.badge.img+2
Good day,
Please assist.
I am running version 11.24.16
Virtual server backup successfully, but SAP Oracle and Archive Logs fail, error is: SAP Oracle Error [SAP BR*TOOLs execution failed. Please check the SAP detail file on client for details.]. Logs uploaded.
  • Services are running
  • Oracle DB is online and healthy
  • Execution of  BR*TOOLS command in the client server goes successfully
  • Error Code: [18:95]
Warm regards,
Glenn Ngobeni
Best answer by Mike Struening
Thanks for the post, Glenn!
I have found a few potential solutions for the highlighted error.
The first one is permissions based. Please have your DBA check the permissions on the folder /oracle/POD/sapprof
Second, please also check the requirements and ensure your version of BR*TOOLS meet the system reqs: https://documentation.commvault.com/11.24/expert/3086_sap_oracle_agent_system_requirements.html
Here are the logs themselves, as you can see, it fails at the same spot twice (likely due to permissions).
Let me know if the above are helpful!
brbackup Script:[brbackup -d rman_util -p C:\tmp\initDQ2.sap_bkup -t online -m incr -c -u / ]brbackup Log:[BR0051I BRBACKUP 7.20 (42)BR0169W Value 'ibs=' of parameter/option 'dd_in_flags' ignored for 'Windows' - 'bs=' assumedBR0055I Start of database backup: bfhqrdlq.inr 2021-10-27 21.00.50BR0484I BRBACKUP log file: F:\oracle\DQ2\sapbackup\bfhqrdlq.inrBR0280I BRBACKUP time stamp: 2021-10-27 21.00.53BR0301E SQL error -31993 at location BrInitOraCreate-7, SQL statement:'/* BRBACKUP AT PROF_CONN */ CREATE SPFILE = 'F:\oracle\DQ2\sapprof\spfileDQ2.ora' FROM PFILE = 'F:\oracle\DQ2\sapprof\sapDQ2.ora''ORA-31993: cannot overwrite parameter file 'F:\oracle\DQ2\sapprof\spfileDQ2.ora'BR0303E Determination of Oracle version failedBR0056I End of database backup: bfhqrdlq.inr 2021-10-27 21.00.53BR0280I BRBACKUP time stamp: 2021-10-27 21.00.53BR0054I BRBACKUP terminated with errors]brbackup Script:[brbackup -d rman_util -p C:\tmp\initDQ2.sap_bkup -t online -m incr -c -u / ]brbackup Log:[BR0051I BRBACKUP 7.20 (42)BR0169W Value 'ibs=' of parameter/option 'dd_in_flags' ignored for 'Windows' - 'bs=' assumedBR0055I Start of database backup: bfhqrfji.inr 2021-10-27 21.22.22BR0484I BRBACKUP log file: F:\oracle\DQ2\sapbackup\bfhqrfji.inrBR0280I BRBACKUP time stamp: 2021-10-27 21.22.25BR0301E SQL error -31993 at location BrInitOraCreate-7, SQL statement:'/* BRBACKUP AT PROF_CONN */ CREATE SPFILE = 'F:\oracle\DQ2\sapprof\spfileDQ2.ora' FROM PFILE = 'F:\oracle\DQ2\sapprof\sapDQ2.ora''ORA-31993: cannot overwrite parameter file 'F:\oracle\DQ2\sapprof\spfileDQ2.ora'BR0303E Determination of Oracle version failedBR0056I End of database backup: bfhqrfji.inr 2021-10-27 21.22.25BR0280I BRBACKUP time stamp: 2021-10-27 21.22.25BR0054I BRBACKUP terminated with errors]CKUP terminated with errors
