SAP for oracle backup - CV doesn't recognize the active node
  • June 21, 2021
  • 208 views
Forum|alt.badge.img+5
Hi Guys, I have a problem with oracle sap backup in a cluster mode
the Commcell doesn’t recognize the right active node, even when I remove one node
Best answer by Gowri Shankar
I am assuming you are referring to an OS level non-veritas cluster with active-passive configuration.
Check the following -
  1. Commvault software is install on all the nodes of the cluster under the same path
  2. Job Results directory resides on a shared volume which can be accessible by all the nodes after a failover
Try a force resyn of the cluster by navigating to the cluster pseudo client from commvault console right click → Properties → Advanced options →  Under Cluster group configuration →
Make sure all the nodes and the agents are selected
Check the box the resyn cluster and click on ok
This process will show the active node.
To automate this for a future failover include the cvclusternotify script in cluster startup / shutdown procedures.
For more details check → https://documentation.commvault.com/commvault/v11_sp20/article?p=4990.htm
Forum|alt.badge.img+16
