SAP HANA Backup Issues - Commvault
  • March 10, 2022
  • 1197 views
Mohit Chordia
Explorer
Hi Community ,
Is there any SAP HANA expert here ? We are facing below serious issues with HANA Production backup --
Issues
  • When one of the mount path in library reaches its reserve space during HANA backup job , Instead of HANA backup routing to another mount path of the same library which has sufficient free space,  backup jobs goes to hang status .
  • We have to finally kill backup job from Commvault as it never comes out of hang status or fail on its own , after killing the HANA backup job it creates hang session on DB which doesn’t get cleared on its own and requires a DB restart which becomes an outage for mission critical production database .
SAP has clearly stated that this is not a bug with existing HANA version.
Let me know if anyone has experienced same issue or aware about this issue with HANA Backups ?
Best answer by Mike Struening
Sharing case closure:
Finding Details:
Customers HANA backups when failing because of mount path getting full would cause a session to be left open to HANA which could mean the customer had to restart their DB in some scenarios.
Solution:
The case was escalated to development and it was advised that customer update to MR30 or above as the issue of leaving a session open causing hanging has been fixed in MR30 and above.
Also been advised that mount paths should be shared for read/write + enable option to allow load balancing on multiple data paths during one backup job however not willing to make this change.
Forum|alt.badge.img+5
@Mohit Chordia ,
Do you see this behavior for GUI backups and application command line jobs or only for command-line jobs?
We may need to review this further internally. Please open a ticket and share the logs from a recent occurrence?
Mohit Chordia
Explorer
  • March 11, 2022
@Mahender Reddy
Hi Mahender,
We are seeing this behavior for HANA DB backup which is scheduled and triggered through Commvault. The behavior is not observed on HANA log backups  . Case # 220308-571 has been opened with support .
Finding Details:
Solution:
