SAP MaxDB Agent - Unix LD_LIBRARY_PATH
  • March 14, 2022
  • 639 views
Hi Community,
I have installed the SAP MaxDB Agent on a SLES 15 system at our customer.
The customer is using a "C-Shell" (csh) and not a bash.
Is an environment variable also needed in this case?
dbm_configset -raw set_variable_0 LD_LIBRARY_PATH=/opt/commvault/Base
dbm_configset -raw set_variable_1 SHLIB_PATH=/opt/commvault/Base
Configure the shared library path in the .profile file from the root directory.
For Linux and Solaris:
LD_LIBRARY_PATH=/<software install path>/Base:/<software install path>/Base64
export LD_LIBRARY_PATH
https://documentation.commvault.com/11.25/expert/22203_configuring_sap_maxdb_parameter_file.html
Thanks and best regards,
Andreas
Best answer by Mahender Reddy
@ak2 ,
Those are dbmcli commands.
You don’t have to use OS export commands to set those parameter.
You just need to connect maxdb database using dbmcli and run the commands.
Example:-
Connect the database:-
dbmcli -d <database name> -u <UserName,Password>
Run following commands from dbmcli prompt:-
dbm_configset -raw BSI_ENV <software install path>/SapMaxDbAgent/backint.conf
dbm_configset -raw set_variable_0 LD_LIBRARY_PATH=/<software install path>/Base
dbm_configset -raw set_variable_1 SHLIB_PATH=/<software install path>/Base
Replace software install path(It could be /opt/commvault/Base)
Please let us know in case of any questions.
Mahender
Forum|alt.badge.img+5
@ak2 ,
Example:-
Mahender
  • March 15, 2022
Hi @Mahender Reddy ,
I was aware of that.
Is it necessary to perform the following part?
or are the dbm_configset commands sufficient?
best regards,
Andreas
@ak2,
The second part(dbm_configset commands) is necessary for the Maxdb to read the third party tool like commvault.
