Schecule policy with exceptions
  • March 8, 2021
  • 221 views
Henke
Explorer
I tried out the exception rule in Schedules for the first time, on an Intellisnap backup.
I created a Policy with IntelliSnap Full, SQL Integrity check and backup copy job first SUN of month.
Then I created one with Intellisnap Full Mon-Sun with exception on first sunday.
When I looked it seems that the schedule didn't run at all on the first sunday.
The exception was applied only once to the one MON-SUN. The exception should only be for that schedule I guess?
Or did I get this backwards.
//Henke
Best answer by Henke
@Mike Struening thanks for the reply.
I found out that a collegue changed the specific schedule execution time, hence it looked like it didn’t run over the weekend. So nothing going wrong.
Sorry for the confusion.
I’ll go stand in the corner……. :confused:
/Henke
Hey @Henke !  Can you post screenshots of each?  I’m not sure I’m following you.
Is this one schedule with multiple items within, or 2 separate schedules altogether?
Assuming the former, it sounds like we are applying the exception to everything.
Exceptions are per item within each Schedule Policy (in my lab screenshots, I checked the details on the Incremental portion which has the option for exceptions).
Henke
Explorer
  • March 8, 2021
/Henke
Hey, man….for a Monday morning this was what I needed :laughing: !
Enjoy your “Best Answer” credit :-)
