Schedule overlap
  • January 19, 2023
  • 113 views
Hi
if for a mistake I schedule 2 different job type (Full and Incremental) for a subclient at the same time which job will start ? Full or Incr or will be a “random” choise of Commvault ?
Regards
Federico
Best answer by Damian Andre
It would be random - survival of the fastest thread. There is no logic to handle conflicting schedules to be able to pick the right one to run.
Zubair Ahmed Sharief
With default job management settings, one of the schedules would run and other would fail. The successful job would depend on how the schedules would be configured.
If the setting “queue conflicting jobs” is set (not the default setting) in control panel → Job Management, then both the jobs would start one after the other.
  • January 19, 2023
Hello Zubair
If the setting “queue conflicting jobs” is not set which schedule will start? Full, Incr or random ?
  • January 19, 2023
  • January 19, 2023
It’s seems a random behaviour
Federico
  • January 19, 2023
