Script RMAN
  • June 21, 2022
  • 209 views
Preciso alterar o script do RMAN em um dos meus clients devido sua versão do banco não suportar mais de um canal.
Best answer by Sunil
You can just select 1 stream in the subclient properties in GUI. That will create only one channel.
Alternatively, you can also customize the script in the backup dialog. But I guess this is not needed if you set streams to 1.
Sunil-
Sunil
Forum|alt.badge.img+16
  • June 21, 2022
Sunil-
  • June 21, 2022
thank you very much Sunil, i found the parameter in storage device and the execution was successful using only one channel!
