sending autherization when deleting client 11.34
  • Jan 17, 2024 7:50 AM UTC
  • 850 views
Forum|alt.badge.img+16
i am user in the master group and trying to delete a client or retire a client , approval sending out , i disabled below workflow ,restarted service still its happening
Best answer by Sebastien Merluzzi
@Ajal ,
Can you check our Documentation:
https://documentation.commvault.com/2023e/expert/using_get_and_process_authorization_workflow_in_commcell_console.html
Sebastien
Hi @Ajal
We have a CMR 309741 for this.
I will check and get back to you.
Sebastien
  • Jan 17, 2024 8:17 AM UTC
@Sebastien Merluzzi  i disabled the process called DeleteAgentAuthorization and its okay now , its a big process , some other admin need to disabl it and all , if there is any documentation that is appreciated
Mohammed Shereef P
@Ajal
Disabling the "Get And Process Authorization workflow" may disrupt other business logic processes, such as the "Delete Library Mount Path Authorization workflow," which is crucial for preventing inadvertent deletion.
If deleting or retiring a client is the sole issue, maybe remove the "Delete Client Authorization workflow" instead.
