Snap copy and Backup Copy
  • September 12, 2022
  • 1715 views
Marco Lachance
Explorer
Hi, I’m not working a lot with Snap Copy and one of my customers wants to use it in this way !
Multiple Snap during the days, let’s say one every hour but he wants to have a backup copy of the last one of the days only and he is using Plan to manages is environment.
Best answer by Collin Harper
@Marco Lachance
I believe this is the configuration you would like (screenshot below).
You will need to set the selection rules to Daily (by default the “day” starts at 12am) and the last full backup. Note that selective backup copy will only copy Full backups. If you only run 1 Full backup per day the “first full backup” or “last full backup” of the time period is irrelevant.
Thank you,
Collin
@Marco Lachance
Under the Storage Policy properties and Snapshot you can specify the rule:
https://documentation.commvault.com/11.24/expert/60105_storage_policy_snapshot.html
I hope it helps.
Sebastien Merluzzi
Hello @Marco Lachance
Do you happen to know which Agent the customer will be using? Virtual Server, Windows\Linux Filesystem, or NDMP?
Thank you,
Collin
Marco Lachance
Explorer
VSA and NDMP
  • September 15, 2022
@Marco Lachance
Thank you,
Collin
