Sql always on Admin not see incremental backup
  • February 9, 2025
  • 108 views
Forum|alt.badge.img+5
Sql always on Admin can no longer see incremental backup in SQL management studio, only see full backups
Are there any special settings?
Best answer by Mohamed Ramadan
I don’t believe you can do an ‘incremental’ backup of SQL. You can do a Full, Differential and Translog.
From: Backups of SQL Always On Availability Group Instances
You back up Always On availability group instances the same way that you back up other SQL subclients.
For information about backups of SQL subclients, see SQL Backup Operations.
When you start the backup, the master process retrieves the backup information from the availability group. All activities of the master process are logged in the SQLBackupmaster.log file.
Backup jobs run on the primary or secondary replica as follows:
  • Full and differential backups: These backups always run on the primary replica. Copy-only full backups run on a secondary replica.
  • Transaction log backups: If the primary replica is set as the preferred replica for running backups, then transaction log backups run on the primary replica. Otherwise, the transaction log backups run on the secondary replica that has the highest backup priority.
hello ​@Ponte_Vedra
Yes, some DBAs refer to differential backups as incremental backups.
this tool could be really helpful for you ​@BillyBoo , or Commvault also has a tool called the CvSQLBackupUtility Tool.
You can find more details here:
https://documentation.commvault.com/11.20/available_operations_for_cvsqlbackuputility_tool.html
Mohamed Ramadan
Data Protection Specialist
Mohamed Ramadan
Explorer
Forum|alt.badge.img+13
hello ​@BillyBoo
are you currently using the Commvault plugin for SQL Management Studio?
Mohamed Ramadan
  • February 9, 2025
Hi ​@Mohamed Ramadan   no not using
Mohamed Ramadan
Explorer
hello ​@BillyBoo
Thanks for the update!
Could you try using a tool like dbatools with the following command?
Get-DBALastBackup -SQLinstance Instance
Also, could you please share the SQL queries you've used?
Mohamed Ramadan
  • February 9, 2025
Mohamed Ramadan
Explorer
hello ​@Ponte_Vedra
Mohamed Ramadan
  • February 11, 2025
Thank You ​@Mohamed Ramadan
