sql and oracle transaction log backup ,schedule settings
  • April 21, 2023
  • 308 views
Forum|alt.badge.img+16
 for sql backup schedule
 i need to take db backup full daily and transaction log backup hourly , its 2 node windows cluster
i created one schedule for sql db backup and created seperate tasks for db and logs
 below for  db backup task
and i created another task like below for transaction log backup
is this right way , because i am getting below for the sql backup summary
where as i am running oracle backup
since it shows archive as deferent instance
as well since it shows the archive instance separately i created another schedule policy for archive backup same as above but it shows 2 jobs running hourly for oracle
can someone help me correct way of scheduling db and log backup for oracle & sql
Best answer by Gowri Shankar
un-associate the default sub-client from the policy which triggers an hourly backups and assign the policy which has schedule for the full backups
Hi @Ajal
Oracle backups work slightly different from other database agents. By default we create default & Archive log sub-clients.
If a backup is scheduled on the default sub-client by default it will perform full & archive log.
Archive log sub-client will perform logs only backup.
To better align oracle backup would recommend to use a separate schedule police for oracle backups.
1 schedule to initiate backups of default sub-client which contacts full
  1. Archive log sub-client to perform hourly logs only backup
Hope this helps.
Regards.
Gowri Shankar
  • April 21, 2023
this is how i have done it for oracle , however i can see 2 backup running hourly  as you can see below one is default and one is archive log
  • April 21, 2023
  • April 21, 2023
ok @Gowri Shankar  i will check that if its associated with it,
what about sql , can you help me there
how to create a task for log hourly full backup and daily db full backup
