SSO problem
  • March 15, 2023
  • 63 views
hey
We recently upgraded the system to version 11.28.49 and something go wrong in sso
do u know what i can do about it??
Best answer by Chris Hollis
Hi @HaimCo,
Mind sharing some extracts from the evmgrs.log on the Commserve?
Try login to replicate the failure, then open this log from log folder directory (default path - C:\Program Files\Commvault\Content Store\Log Files) and around about that time stamp we should get a bit more information on the failure.
Share the extracts here (after you mask anything sensitive).
Chris
Chris Hollis
  • March 16, 2023
Hi @HaimCo,
Chris
