Stale Hypervisor Entry in CommandCenter
PedroRocha
Byte
During configuration of a hypervisor I had to create and delete it a few times. Using Commcell Console… suddenly, there was an Entry showing in Command Center that I could not manage/delete. And that entry did not exist in Commcell Console. Only in Command Center.
How to delete it?
If I click the entry:
Pedro
Best answer by PedroRocha
Orazan,
I noticed that after some time, the stale entry gets removed. I believe that there is some lag between operations performed in the Commcell Console and the Command Center.
Pedro
  • 630 replies
  • April 16, 2023
Good afternoon.  Are you logging in with the admin account when  you see this or a user account?  If a user account, what is the behavior when logged in as admin?
PedroRocha
Byte
  • Byte
  • 80 replies
  • April 17, 2023
Orazan,
Pedro
Onno van den Berg
Commvault Certified Expert
Yes, this unfortunately happens. A lot of actions are lazy or use some form of a scheduling engine under the hood.
Cookie policy
Cookie settings
