Starting Incremental Backups for Selected VMs in a Subclient
  • January 28, 2021
  • 880 views
Hello Everyone
We run a frequent patching schedule and we are asked to make sure that we have latest backups available for those servers. These servers belong to multiple subclients and we are at the moment manually triggering the incremental backups for those subclients and this takes time as we have to initiate the backup of whole subclient even if only one VM is being patched out of those lets say 20 VMs.
What is the best way to approach this without moving the VM out of the subclient.? Or is it possible to trigger incremental backups for selective VMs inside a subclient. We are at SP20.
Thank You
Best answer by MFasulo
In command center go to protect > virtualization > VM tab > find the VM > backup.
MFasulo
  • January 28, 2021
  • January 28, 2021
@MFasulo Thank you for the answer.
I did try with VMware workloads and it was successful, I was able to trigger individual VM backups for multiple VMs in a subclient, but when I tried with our Azure workload. I could start only one Job at a time. The second Job failed with an error:
Another backup is running for client XX, Backupset YY, Subclient ZZ.
Any way around this particular situation.
  • February 1, 2021
How long have these subclients been set up? You might need to migrate them to V2 indexing if they have been around since before you went into V11 Commvault. I had to do that and migrate our vcenter into a V2 indexing version. With V2 indexing you can run backups of individual machines instead of the entire subclient.
Unfortunately Indexing V2 is not yet supported for Microsoft Azure Virtualization Clients: https://documentation.commvault.com/11.22/essential/114216_vm_centric_operations_in_command_center_vsa_v2.html - therefore the “VM Centric operations” won’t be available and the single VM backup is actually an “ondemand” backup of the subclient - so you can only start one for the same subclient.
It will work for any indexing V2 enabled virtualization client similar to your experience on VMware.
  • February 2, 2021
@Christian Kubik @Jake Thank you guys. I spoke to the account manager and he mentioned that FR23 is expected to include support for Index v2 for Azure and Hyper-V clients.
