Hi Community,
Same environment as above: one CommServe at HO and 4 remote sites, each with its own on-prem MediaAgent and Disk Library (primary copy).
Planned design:
- Primary copy: local Disk Library at each site (30-day retention).
- Secondary copy: Commvault Air Gap Protect (Azure), with extended retention of 3 years for Prod and 1 year for Non-Prod.
- Remote sites: direct internet (HTTPS 443) plus site-to-site VPN to HO.
Questions:
- Once AGP is licensed and configured on the HO CommServe, can each remote site's MediaAgent be added as a data path and write the Aux Copy directly to AGP, without routing data through HO?
- Is any extra license or install needed on the remote MediaAgents for AGP, apart from opening outbound 443?
- What's the recommended approach: one shared AGP storage pool with all 5 MediaAgents as data paths, or a separate AGP storage per site, each with its own DDB on the local MediaAgent? We want to avoid DDB lookups over the WAN/VPN.
- MediaAgents added through a client group get Read access by default. Do we need to change it to Read/Write for each remote MediaAgent before running Aux Copy?
- Can one AGP subscription (capacity) be shared across all storages and sites in the same CommCell?
Thanks in advance.
