Storage Pools for Intellisnap Snapshot Copy
  • February 8, 2022
  • 199 views
We are in the process of retiring our old Media Agents and as part of this process we have created all new storage and global deduplication policies to replace our old ones. During the process we noticed that we now have the ability to configure the snapshot copies to utilize storage pools instead of tying them down to a specific library. Question I have is whether there are any downsides to using using a storage pool verses a library. As we have our media agents configured in pairs of two, it would seem that a storage pool would provide more resiliency in the way that if the primary library is down the secondary library in the group can process the backup.
Best answer by Ledoesp
Personally I prefer to avoid creating a snap copy and associate it to an Storage Pool, as in general it is a global deduplicate storage policy, basically there is no dedupe in place when using IntelliSnap, unless my Storage Pool is created without dedupe.
I prefer to specify the data path(s) I want because I can change it later if I need to, something that it is not possible when you associate to an Storage Pool.
Storage Pools are just an easier logical method to tie a library and a Storage Policy together.
Going forward, the default option will be to use a Storage Pool.
No downside here, just a more logical connection between the resource and the policy options.
  • February 8, 2022
  • February 9, 2022
Thank you both for the great feedback, very much appreciated!
