Stuck Failed Job in Job Controller
  • June 20, 2023
  • 8 replies
  • 778 views
PedroRocha
Explorer
Hi!
Any clue on how to remove that failed job from job controller (it's stuck in there)?
Best answer by Scott Reynolds
@PedroRocha If you have restarted CS services and the job is still stuck probably need to open a support case for further assistance
Rajiv
  • June 21, 2023
Hello @PedroRocha
If you have a recent DR backup, could you plan a downtime and try to restart the Commserve services and see if that helps clearing out this entry?
Best,
Rajiv
PedroRocha
Explorer
  • June 21, 2023
Hello @PedroRocha
Best,
Rajiv
Hello Rajiv… we tried that.. no luck. We have a failed and a killed job that are stuck in the job controller.
Hi @PedroRocha ,
Is this on the Commserve Console itself or Remote Console?
Sebastien Merluzzi
PedroRocha
Explorer
  • June 21, 2023
Hello!
It's on the Commcell Console, locally to the commserve server.
@PedroRocha ,
You already have a case, we will check and get back to you.
@PedroRocha ,
What do you see in jobmanager.log for these 2 jobs?
Also, it is better to send the CS DB along the logs also so we can check in Staging.
Updating the RCA here:
Customer deleted storage policy while job was running, and job can’t be completed because entry can’t be added to history table.
