Support for Openshift's OADP for backups?
  • January 14, 2022
  • 910 views
Trying to understand if it makes sense to leverage their backup API.
https://access.redhat.com/articles/5456281#what-is-oadp-2
Thanks.
Best answer by Stuart Painter
Hi @Skarra
We have support for RedHat OpenShift natively in Commvault:
RedHat OpenShift
Commvault only backs up applications that have persistent volume claims (PVCs).
Red Hat OpenShift: System Requirements
Commvault recommends that the existing users of the Red Hat OpenShift VSA solution migrate their backup operations to the Kubernetes solution, to backup and restore additional containerized data types.
Note: Red Hat OpenShift Container Platform versions 4.2, 4.3, 4.4, and 4.5 are supported by the <Kubernetes> solution only.
Stuart
Hi @Skarra
RedHat OpenShift
Stuart
  • January 17, 2022
Thank you
