System Requirement for Media Agent on Orcale Cloud
  • December 7, 2022
  • 159 views
Forum|alt.badge.img+9
Hi All,
Does Commvault support Media Agent and Commserve on Orcal Cloud. if yes, please provide system requirements fo MA on OCI.
Rahul Raina
Best answer by Collin Harper
Hello @Rahul18081
For the MediaAgent to communicate with the storage, we use cURL API calls over HTTPS.
Thank you,
Collin
Hello @Rahul18081
I hope this documentation helps answer your questions. You can find the MediaAgent System requirements, Hardware Specifications below. WE have no specific requirements for OCI hosted MediaAgents.
MediaAgent: System Requirements - https://documentation.commvault.com/11.26/expert/2822_mediaagent_system_requirements.html
Hardware Specifications for Deduplication Mode - https://documentation.commvault.com/11.26/expert/111985_hardware_specifications_for_deduplication_mode.html
Thank you,
Collin
  • December 7, 2022
@Collin Harper Thanks for the update. My last query is what are the port requirements for Media Agent on OCI with Oracle Cloud Infrastructure Object Storage to configure Oracle Cloud Library.
Thanks in advance
  • December 8, 2022
Hello @Rahul18081
Thank you,
Collin
