System State Backup for Ubuntu
  • Sep 5, 2024 1:33 PM UTC
  • 65 views
While taking system state backup of Ubuntu I am getting error “resopnse file creation failed”.
Hey @Saumitra,
the most likely reason is that the version of Commvault you are running does not support the version of Ubuntu you are using.
Check here: https://documentation.commvault.com/v11/expert/1_touch_for_linux_system_requirements.html
You might need to adjust the documentation version based on what you are running to get an accurate reflection.
