Tape refresh configuration
  • October 24, 2024
  • 69 views
Forum|alt.badge.img+5
Dears
I have many tapes kept for only one un-aged jobs and I plan to perform tape refresh on specific tapes picked manually.
When I try to enable media refresh on storage policy copy level I see the parameters for auto picking tapes.
How to bypass these parameters ?
Hello @Ahmed Elbably
If you navigate to the tape library you can manually select each tape for refresh or perform tape to tape copy from it directly. If you go from the SP level it will always try to follow a patten for automation reasons.
Kind regards
Albert Williams
  • October 28, 2024
Dear @Albert Williams
Thanks for your reply.
I tried to pick some tapes for refresh but it’s mandatory to enable Media refresh on SP Copy level first.
How to enable Media refresh without Providing these parameters ?
In other words, How to bypass these parameters ?
BR
Ahmed Elbably
