Test Net Connection not working on DR CV Node
  • February 3, 2023
  • 53 views
Hi Guys,,,,
We are not able to perform TNC on ports 8400 and 8403 to DR Commserve node.
Is this because the services are stopped on the DR node ? Its a Live-Sync DR configuration.
pank1988
Best answer by Jos Meijer
Hi @pank1988
When the Instance001 services are stopped you cannot communicate on 8400 and 8403 as there is no binding.
Instance002 is online in a CS LiveSync setup and by default has bindings on 8405 and 8408.
Jos Meijer
Forum|alt.badge.img+21
  • Community All Star
  • February 3, 2023
Hi @pank1988
