I have a few questions regarding the documentation for testing IOPS for both the DDB disk (https://documentation.commvault.com/2024e/commcell-console/testing_iops_of_deduplication_database_disk_on_windows.html) and the Disk Library (https://documentation.commvault.com/2024e/commcell-console/testing_iops_for_disk_library_mount_path_with_iometer.html)
- The documentation states to run the IOMeter test “on the complete raw disk”, and “IOMeter allows allows physical disks to be selected only when there are no volumes on the disk”. Does this mean that the disk should not be formatted before running the IOMeter test?
- For the Disk Library, I am mounting a LUN from a SAN to the MediaAgent that is about 48 TB. What is the best way to test IOPS for this? I am guessing I will need to set the Maximum Disk Size, otherwise creating that huge iobw.tst file would take ages.
- Is the CVDiskPerf tool the preferred method testing Disk Library (like the above)? https://documentation.commvault.com/2024e/commcell-console/disk_performance_tool.html
