there is no agent for sql in 11.32
  • September 13, 2023
  • 10 replies
  • 142 views
Forum|alt.badge.img+16
which agent to be installed in sql server
Best answer by Sebastien Merluzzi
@Ajal ,
MSSQL is the Agent you need.
I have downloaded the latest Media Kit:
https://cloud.commvault.com/webconsole/softwarestore/#!/130/655/27215
HI @Ajal ,
I see SQL Server in your screenshot, what is the issue?
Can you check our Documentation:
https://documentation.commvault.com/2023e/expert/114796_commvault_packages_available_for_windows_computers.html
Sebastien
@Sebastien Merluzzi  this is ffrom 11.28 in 11.32 there is no sql server instead it is mysql agent
@Sebastien Merluzzi
Did you download the Full Package?
I will Test in my lab.
@Sebastien Merluzzi  yes , i checked 2 environment its same , i tried to add the server via command center then i could see that it is pushing mssql agent
secondly while scheduling the sql server job we dont have option for translaction log which we had previosly its now icnremental
@Ajal ,
@Sebastien Merluzzi  can you also check the schedule policies for sql server
@Ajal ,
We just renamed it, it is the same thing.
@Sebastien Merluzzi  so in the schedule i can just select increment for tlogs
correct.
