Total Data Processed vs Total Data to Process
  • April 18, 2023
  • 184 views
I would like to understand why when I see 32.35TB to be copied to tape, the aux copy is completes 100% successfuly, but the Total Data Processed (29.69TB) is less than the Total Data To Processes.
Forum|alt.badge.img+18
  • April 18, 2023
Good afternoon.  Can you verify if the setting “Disable jobs for Auxiliary Copy that met its retention” is set in the Media Management configuration as seen here:
 Your Aux Copy ran for a long time.  If any jobs were set to age in that time they wuld not be picked for Aux copy if this setting is enabled.
  • April 25, 2023
This parameter is currently set to 1/enabled.
