Hi Team
While configuring a Cloud Library we would like to have separate IAM roles for different Buckets pointing to different AWS location, how can I achieve this?
Hi Team
Best answer by Winston W
Hi Jon
By default Commvault will propogate the IAM credentials to other Shared path based on the IAM policy set on the preferred Device Controller
You can change this behavior and have different IAM credentials assigned to different Bucket within the same Library by changing the following setting (Media Management - https://documentation.commvault.com/commvault/v11/article?p=11022.htm)
Update cloud library credential to selected device controller only:
Definition: When this option is enabled, you can set different access credentials for individual device controller on the same cloud device.
Default Value: 0
Range: 0 (disabled) 1 (enabled)
Usage: When this parameter is disabled, any changes made on one controller of the cloud device will be copied to all the other existing controllers. When the parameter is enabled, then from CommCell Console you can modify the access credentials of only the edited controller.
After this MMConfig option is turned on, from the mount path sharing edit the second credential to access the cloud library path .
Once you change the setting to "1" the IAM role does not automatically propgate the IAM credentials and allows independent IAM roles assigned to different MediaAgent with in the same Cloud Bucket
Kind Regards
Winston
