Unix Failover Cluster and Job Results folder on NFS
  • March 4, 2022
  • 126 views
Setting up a backup for a Solaris Cluster.
Got a question if we can have the Job Results folder on an NFS mounted volume on the Cluster Group?
I have had the Job Results Folder on net-shared volumes before but never in a cluster group setup. Is it supported?
/Patrik
Best answer by Gowri Shankar
Good day @Patrik ,
Yes,  the job results can reside on a NFS volume which is mounted on all the nodes of the client.
When the cluster fails over the job would access the collect files residing in the shared location
Please make sure commvault is installed on the same path on all the nodes and the job results path is same on all the nodes.
Let us know in case of any other questions.
Gowri Shankar
Forum|alt.badge.img+13
Good day @Patrik ,
Gowri Shankar
