Upgrade Commserve on new hardware machine
  • August 27, 2021
  • 9 replies
  • 727 views
I have CommServe backup server (two Media Agents  with many machines, with Linux Data Agent, also virtual machines) version simpana 11.20.0 installed. I have to plan migrate our existing CommServe (installed on Windows 2012) to a newer hardware with better performance and Windows 10.
Which documentation do you recommend? Which method of install to use for upgrade?
I have found https://documentation.commvault.com/commvault/v11/article?p=2224.htm
Thank you!
Best regards,
Elizabeta
Best answer by dude
Release Types
Feature release → Once every quarter → One (1) year from initial release.
Long-term support (LTS) feature release → Once every year → Three (3) years from initial release, with monthly maintenance releases for year 1 and year 2, and then as needed.
Refer to: https://documentation.commvault.com/11.24/essential/2619_feature_release_schedule_and_lifecycles.html
  • August 27, 2021
Elizabeta,
Since you are just changing the hardware of the Commserve, the following documentation is what you need to follow:
https://documentation.commvault.com/commvault/v11/article?p=4739.htm
Just be sure to use the media for the same version you are currently on.
Tom
MichaelCapon
Hello @elizabeta ,
Is the CommServe just a CS or does it have any other roles? (i.e Media Agent)
That’s the correct link to move and upgrade the CommServe to new Hardware.
Essentially you run a DR backup, Build the new CS and point the installer to the latest DR Backup in Database options.
Michael
  • August 27, 2021
Thank you  @tmk  for your answer and link for documentation. First, I would like to ask is simpana version 11.20 the last recommended simpana?
Thank you!
BR,
Elizabeta
  • August 27, 2021
Currently we are on Feature Release 24 which like 11.20 is a Long-Term Support Release.
The following link shows the different releases for you to review.
  • August 27, 2021
Hello @elizabeta ,
Michael
Hello @MichaelCapon ,
The CommServe is commvault backup server installed on machine. Also, on the same windows machine is installed one Media Agent (which communicate with Tape library).
BR,
Elizabeta
  • August 27, 2021
So,
Is it okay to stay on this version of simpana 11.20 ?
BR
  • August 27, 2021
Hello @tmk ,
Which means “Long-Term Support Release”?
BR,
Elizabeta
dude
Forum|alt.badge.img+20
  • Community All Star
  • August 27, 2021
Release Types
  • August 27, 2021
Release Types
Thank you  @dude !
