Upgraded to Commvault v11.44.xx from v11.36/ Health Section Not Updated
  • Nov 22, 2026 8:47 AM UTC
  • 19 views
Upgraded to Commvault v11.44.xx from v11.36. After the upgrade, the Health section of the Command center has not updated since the upgrade.  The Command center/web server is also the Commserver. Has anyone encountered this issue and is it a known issue whe upgrading to v11.44 Commvault? If yes, is there a known solution?  We have already upgraded to v11.44.31 and same issue exist. Last update from Health section was prior to the upgrade.
  • Nov 24, 2026 2:18 PM UTC
Hi Lili,
Since the Health section was updating before the 11.44 upgrade and has remained stale even after updating to 11.44.31, I would suggest opening a Commvault Support case so they can investigate the Health data collection/update path and the relevant Web Server/CommServe logs.
It would be helpful to provide Support with the upgrade timeline, the last Health update timestamp, screenshots, and confirmation of whether other Command Center dashboards are refreshing normally. This should help determine whether the behavior is specific to the environment or related to the upgrade.
Please share the outcome if Support identifies the cause or resolution.
